Originally Posted by RIOT
DON'T SMACK IT!......DUMASS!
Anyway there are clips behing it but if you smack it wrong they will bend and no longer work.
Had same problem after so long of putting it back together I took the car in and had them replace the clips under warranty.
I tell you in a roadster that will scare the **** outa ya at speed popping out and whistling away!
It would keep popping out after repeatedly taking the roof down and high speed interstate runs....it kept getting worse....I think the clips wear out from being used over and over...so I took it in and had the dealer fix it and no problems since.
does this clip situation only exist on roadsters or is it the same setup on the coupes? i have a wind issue as well and the bulk of the noise seems to be coming from the plastic "triangle" towards the foward part of the windows.
