Originally Posted by Coyote
Dude, it was your set up that made me want to put them on my car.
So... something doesn't seem right with this equation. I'm adding a value
on one side of the equation (more air) but not getting anything on the
other side (more boost). One would think, but could easily be wrong, that
putting more air in the compression chamber would result in more
pressure during compression. But, who cares
, some mods are just
for the look, and these look awesome.
Coyote
boost will remain the same until the speed of the compressor is changed. the inc in air to the chamber is the one side of the a/f ratio not boost. by using the horns your adding colder air and more air than stock. so in theory you should be leaning a bit if you havent tuned
i wrapped my tubes with black exhaust wrap to keep the engine bay heat off them. before the wrap you could literally burn your hand on the tubes,(mine are stainless steel) after the wrap you can hold them all day they are just warm toi the touch. 10ft should wrap them properly
and they look really cool!!
