Tip! The Scanner Tool Hookup slides over, and then the actual wires slide out. Took me about 15 minutes to figure this simple step out.
Another Angle
Void the Dremel, I only actually needed it one time. Do NOT use it to take the plastic molds off, it will only melt the plastic making it a PITA.
Same.
Plastic Molds
Use a Razor to Cut the Padding away from the Molds
7 Plastic Molds
Easiest way to do it.
It Worked!
All Gone!
