Old Mar 15, 2010 | 09:59 AM
32krazy!'s Avatar
32krazy!
Default Re: Brakes Squealing...
Originally Posted by SoftballJunnkie
After doing some research on the site its best to completely replace the rotors. After looking at the rotors the previous owner def had them turned. I'm just going to replace them with new pads and upgrade the rotors to cross drilled/slotted and hope for the best.
dont hope for the best! do some research and match your pads to your rotors. bed the pads if needed and use brake lube for the pads. clean everything completely and you shouldnt have any issues.
the higher metal content in the pads the more squeal. look at the ceramic composite pads
the type of rotors depends on your driving style. oem rotors provide the most pad contact, slotted rotors scrape the pads cleaning them but shorten the pad life and drilled rotors cool better but tend to crack under extreme use.
