Originally Posted by rcompart
I'd recommend getting the DashDaq / ZT-2 combo with 3.5 Bar(50PSI) transducer for MAP from Rob at NeedsWings and the mount from me. If you're really into monitoring every aspect of your car like I am, add a 10 Bar (150PSI) transducer for fuel pressure, another 10 Bar (150PSI) transducer and one of MikeR's custom fittings for oil pressure, an IAT sensor for post SC air temps and a fluid temp sensor to monitor the coolant temp going into the intercooler. You can actually start to get really crazy if you want but these are the ones you really want to monitor. You could add oil temp to the mix but at the moment, there really isn't an easy way to get the temp of the oil actually being pumped through the engine and oil galleys, only a sensor that replaces the drain plug and that will just tell you the temp of the oil in the pan. Not that it's not good to monitor it but if you're going through the work of installing all these sensors, you want it to give you as true of a measurement as you get.
Feel free to PM myself or Rob with any questions.
Thanks
WILL THIS DEVICE MEASURE AMPS DROP AS THE BATTERY TEMP INCREASES???
