Thread: DashDaq Install
Old Mar 21, 2010 | 11:05 AM
32krazy!'s Avatar
32krazy!
Default Re: DashDaq Install
Originally Posted by rcompart
Give me a shout if you have any questions regarding the install. My number is 952-292-4477. HERE is a cheat sheet to use to install the ZT-2. The wire colors may differ slightly from our cars to yours but the pins are all the same. Good luck and nice buy on the setup.
thanx! looks like shelton marked all the wires for me to do the install and im seeing about 5 wires that have to be soldered into the ecu harness. the hardest part looks like dismantling everything to hide all the wiring!!
im going to polish the y pipe while its off and also need to get a bung installed on the exhaust.
quick qeustion though. what size drill bit do i need to drill and tap the y pipe? 1/8 npt fitting correct?
