Old Mar 21, 2010 | 04:04 PM
70GT6's Avatar
70GT6
Default Re: Headlight headache...do you have water in you trunk?
Another source for the leak can be the rear wing.
There are small o-rings that if torn or out of position will cause a leak.
If they leak, water will follow the plastic trim and drip in to the rear well.
I removed my rear wing cleaned the area and used silicone gasket maker instead of the o-rings to seal the wing bolts.
Worth a look. You will know if they been leaking because the area will be a bit rusty.
