Originally Posted by plainfire
I thought the rev limiter was higher like 62-6400 anyways? except if not moving? good idea about this hydraulic clutch tip. I would like to go 17' all around. Why is single better than a double CAI?
Nope. 5470 on the manual.
If yours is goinghigher, somebody changed them post factory.
The single CAI is more available. The double versions had a problem with turbulence but recent models from Needswings seem to have that solved, thanks to Woody's designs.
Installations look really cool too!
Doc is right, the singles are lower in cost. And installs are far more simple.
17's would give you a lower stance and some help on the accelerations. Moment arm will be lower and the wheel mass will decrease. Not sure the Trac control will like it.
Car will look like a ricer won't it?
roadser with a stick
