Old Apr 1, 2010 | 08:48 AM
velociabstract's Avatar
velociabstract
Default Re: NEED HELP with S/C pulley!!!
Remember that our independent rear suspension will increase negative camber when it squats under power. See post 11.
https://www.crossfireforum.org/forum...t-img_0806.jpg
DISCLAIMER: I run 2.29º negative camber in the front and 2º negative camber in the back. See the difference between the front and rear under full throttle at the top of 2nd gear? Shouldn't they look the same? With lots of negative camber I believe the tires will spin even with drag radials. But, I could be wrong.
Les
