Old Apr 1, 2010 | 08:47 PM
BruceIDE's Avatar
BruceIDE
Default Re: Need a 2005 Crossefire CD for the GPS
[quote=Mike-in-Orange]UPDATE: As of 8.31.2007 these seem to be working. Please read all notes below.
These disks are for the
Infinity Modulus System only, they will not work in other NAV systems. So to share the wealth, so to speak, I have both sets of files sitting on my FTP server and links to both right here:
East Region Nav CD (622MB)
West Region Nav CD (467MB)
Be warned, the files are quite large and are in .ISO format. The following instructions should result in working disks - I tested both methods and produced working disks both ways.
Make sure to use the correct media for this project: CD-R media is the ONLY media that will work. CD-RW discs or DVD media of any type will not work in your Crossfire's
NAV unit.
Windows Computers:
Using Nero Burning ROM:
1. Launch Nero and close out the "New Compilation" popup window
2. Select "File" > "Open"
3. From the "Types of Files" selector, choose "Image Files (*.nrg, *.iso, *.cue)" and then browse to the file you downloaded (either XFIRE_USA_0015.1.iso or XFIRE_USA_0015.2.iso) and select it. NOTE: you will not be able to browse to the file until you have chosen the correct file type from the dropdown menu
4. From the "Burn" tab, select "Finalize CD (No further writing possible)" and next to "Write method" select "Disc-at-once"
5. Select "Burn"
6. Once burning is complete the disk should be useable in your
NAV system
quote]
Nero - Nero - free downloads - latest updates and trial versions
