Old Apr 5, 2010 | 10:53 AM
tighed1's Avatar
tighed1
Default Re: AT Tranny stuck in gear
Originally Posted by Xfire04/82
The code coming up was P0715 Turbine/Speed Sensor, so I had a friend (MB mechanic) replace the electric plate (AT oil, electric plate & new filter = $312) but he had a cheap OBDII scanner and it wouldn't remove the code. Going to go have the code removed today.
Anyone know if I will need to have Transmission Adaptation after replacing the electric plate? or should the car be able to relearn the gears on its own?
Gears are controlled by the TCM. The "electric plate" is nothing more than electrical wire runs and changing it or the TCM does not require adaptation. (does include the speed sensor also)
Been there done that.
