Rebuilt rearend failure.
Apr 6, 2010 | 10:02 PM
permalink
ProjectMayhem
Apr 2008
888
St. Louis, MO
Well my hopes of a cheaper aftermarket alternative with Dahmer Powertrains was a let down. From what I saw today it appears like they used a cheap bearing. The picture shows the bearing failure on the pinion. The rings and spiders gears look fine so this is unlreated to stock rearend failures. The pictures I took show the bearing on the pinion.
I'm waiting for the final word on what to be done. If a factory unit will be put in or perhaps another rebuild from another company or if Dahmer can produce a unti that wont fail at high speeds...
here's what it should look like
This is on the pinion where it siezed to the shaft.
ProjectMayhem
View Public Profile
Find all posts by ProjectMayhem
