Old Apr 12, 2010 | 01:36 PM
onehundred80
Default Re: replace crank and cam sensors together?
Originally Posted by Chrizar
the car is not throwing a code at all, the dealer said we should replace both just in case im guessing. if there is no code, there would be no point then correct?
Would be replacing the CPS to eliminate the random shut offs, seeing as that is the most common fix besides the relay. which is done already.
The dealer would really like you to replace the whole car while your at it, it's your money and he wants to make it his.
