Lots of folks have had this problem. An electrical feedthrough fails and leaks either it's fixed free(?) or there is a DIY written up by Waldig to -do it yourself.
I just replaced my leaking connector shell today. It was fairly easy using Waldig's instructions. While I was under there I also dropped the pan and replaced the filter, pan gasket, and 116 ounces of ATF. I bought a special dipstick on eBay, but it probably isn't necessary if you just capture the fluid and put the same amount back in. Or, you can use a long ziptie which is what others have done on the forum.
https://www.crossfireforum.org/forum...-ta-daaaa.html
I bought the parts and fluid at the following site. The Adapter Plug Housing, which is the part that leaks, is available at the bottom of the page.
http://store.europarts-sd.com/transm...2002-2009.aspx
