Thread: mysterious leak
Old Apr 18, 2010 | 12:03 AM
maxcichon's Avatar
maxcichon
Default Re: mysterious leak
Originally Posted by Blast Chamber
I just replaced my leaking connector shell today. It was fairly easy using Waldig's instructions. While I was under there I also dropped the pan and replaced the filter, pan gasket, and 116 ounces of ATF. I bought a special dipstick on eBay, but it probably isn't necessary if you just capture the fluid and put the same amount back in. Or, you can use a long ziptie which is what others have done on the forum.
https://www.crossfireforum.org/forum...-ta-daaaa.html
I bought the parts and fluid at the following site. The Adapter Plug Housing, which is the part that leaks, is available at the bottom of the page.
Transmission Fluid- OEM Fuchs-4 Liters 2002-2010
Where in Wisco are you? I'm from Stoughton and moved to Alabama 7 years ago.
