Thread: Won't Start
Old Apr 27, 2010 | 11:27 PM
Infinite's Avatar
Infinite
Default Re: Wont Start
the neutral position sensor shouldnt matter, you can crank the car with it in any gear as long as the clutch is in.
If the clutch interlock switch on the clutch pedal went bad, it wouldnt even attempt to turn over.
Double check that the connection on the alt are secure. even the slightest loose connection can cause issues.
