Originally Posted by Infinite
The brake rotors are what the wheels are bolted to, as far as i can tell, the threads go no further than the thickness of the rotor. So if he has damaged threads, new rotors should remedy the problem
You might want to rethink that after having a closer look at the second pic in the first post.
https://www.crossfireforum.org/forum...-hub-rust.html
The lug bolts pass through the rotor and thread into the hub itself. So, new rotors won't help with his issue.
hopefully, It's just a couple of stripped bolts and there is no damage to the hub. Just as Infinite said, Drilling and tapping for a larger bolt also means drilling the wheel so the larger bolt may pass through it. The brake rotor would no doubt require the hole/s enlarged as well. All this will probably cost more than replacing the stripped hub in the long run!
