Originally Posted by trainwreck2003
My ridiculous alarm started this issue last week and so I've done the same as others and just removed the fuse. However, this not-having-working-locks and dome light thing has gotten old REAL quick. Where is that blood-sucking horn at so I can at least remove that thing until someone comes up with a solution to what the real issue is?
The siren is located under the cowl, between the hood and windshield. From what I have read you must remove the windshield wipers to get at it(the challenging part). The solution I have found though research on the forum is to just replace the siren unit. I have not tested it myself yet, as I am in Florida until Wednesday while the car is in Michigan. I will have it done by the end of the week though and will post my results. I ordered the part from
http://chryslerpartsdirect.com, the part number is 5124443AB and it costs $151.32. Also I have read that replacing or at a minimum testing the battery can help, apparently our cars go crazy if they are not being fed the exact right voltage.
Also there is a good amount of info on the siren R&R here
https://www.crossfireforum.org/forum...lved-read.html
Hope this helps.
