Thread: Door Pins
Old May 13, 2010 | 11:17 AM
kingkub57's Avatar
kingkub57
Default Re: Door Pins
If the trim circle is just a push in type with expanding joints I would try to find some kind of tool that will fit right under it and between the panel, and try to pop it off to get more access to the pin and if you are going to replace them, then wait till you get the new ones and then if you break your OEM ones you have the new ones to replace them.
