Re: Front wheels shake
SIde to side says that the bearings are not the issue, top to bottom says the click could be a ball joint and a good place to consider a better search.
You can lift the weight off the wheel and try lifting the wheel with a long 2x4 to see how much play you may have. Swapping the wheels can also be a lo to no cost diagnostic test.
You have some ideas to follow up, good luck to you, Woody.
Do a search on the google as see how to check ball joints for more info.
