Don't be surprised if you get flamed about this question.
I am going to assume this is a legit question, in that case, the numbers 1 through 4 then the big D are indicators of the gears being used, with one being first (lowest) and so on with D being 5th gear (highest).
1st gear is where you will start from a stop. This gear, much like a bicycles low gear, allows you to get the wheels turning from a stop and requires the engine to push hard. As you accelerate and gain momentum, you need less push to get the car moving faster and as a result move up to higher gears. When in a steady state speed and needing to get a burst of speed (to pass a car or enter an on ramp to a highway), you will need that extra push and consequently will need to go back to a lower gear.
The auto-stick when left in the fully auto mode will do this all for you. When choosing your gears, it will hold that gear until it reaches a specific speed (and RPM) then will automatically upshift if you have not done so manually to protect the engine. In turn you can use the auto-stick feature to help slow the car requiring less brake input by using the engine speed as a brake.
So to answer your basic question, no the car will not accellate faster or smoother from a stop more smoothly in a higher gear (as you said 4) than using a lower gear (1). On the other hand, if the car is already rolling, depending on the speed it is traveling, droping it to a lower gear can cause the car to slow without stepping on the brake.
Tried to explain this in the most simple of terms.
Originally Posted by j.j.gue125
Can someone please give me a lesson on the autostick. Do I start in 1 or 4. Sounds stupid I know. Only reason I ask is because when I started in 1 it felt like the car was struggiling to accelerate. Once I switch to 4 it seemed like it was driving normal. Help please.
