Old May 24, 2010 | 02:31 AM
Infinite's Avatar
Infinite
Default Driving impressions with cut srt springs
I've had the cut springs on my limited for about 4,000 miles now so I figured I'd post up my thoughts.
Compared to stock suspension, its so much better. With the stock springs, the car felt unsure though hard corners and had a tendency to wander down the highway. Also, the stock springs are just way too soft for anything other than spirited city driving.
I picked up my springs from bhayes, as well as 1 dot spring pads all the way around. I removed a coil from the front and a coil and a half in the rear. I wanted to see just how low I could get the car and still keep it drivable. I ended up making custom polycarbonate shims for the front spring pads to get the ride height where I wanted it.
The car with the srt springs is an entirely different animal. It feels firm, planted and confident. Turns/exit ramps I was afraid to take at 65 I can now take at 90 flat out and the car seems to ask for more. Gone is any sign of body roll. The car will take any turn at speed and remain flat. The car also tracks straight down the highway now, it doesnt want to wander with every groove. This is mostly attributed to the increased negative camber im running front and back. This car seems to love large amounts of negative camber.
Its a little bit harsh on the highway, you feel every bump and ripple in the road. Car has a more direct feel with the ground. Bridge expansion joints are evil though.
As far as the srt spring rates go. The rear is spot on but the front is still a little loose/bouncy for my taste. The fronts could probably use another 75-100lbs of spring rate for my driving style. I can say for 100 bucks and a few weekends of my time, I'm pretty happy with the springs at the moment. I was going to get some spring blocks to bump the spring rate in the front a little bit and see how I like it.
