Re: Technical Information Database
Josh,
First many thanks for your invaluable offer.
1. VIN:1C3AN65L85X028031. 2005 Limited Roadster.
2. Drivers side heated seat completely inop. Passenger side back only
works.
3. Have P/N for Heated Seat Element Repair Kit (68000519-AB).
4. In the event replacing the element (bottom) or connector (back) doesn't
correct the problem, is the following from the 2006 Parts Manual (Figure
8-805, Item 1) the correct p/n: 05097522AA for the Heated Seat
Module ?
5. The repair (2004 only non SRT repair manual on forum) manual describes
the module as being part of the heated seat switch assembly.
6. Also the most current p/n for the Fuel Relay Control Module and Crank
Position Sensor.
Thanks again.
Tim
