Old May 27, 2010 | 04:18 PM
BLK04LMTD's Avatar
BLK04LMTD
Default Re: Technical Information Database
Tim:
The part number 05097522AA is the correct part number for the heated seat switch.
As far as the fuel relay goes I assume you are talking about the fuel pump relay (the only thing I could find when I searched 'Fuel Relay Control Module') in the tech portion of my service database as well as parts. The part number for the fuel pump relay is : 05099007AA
And the part number for the crank position sensor is : 05080350AA
Hopefully this helps you out a bit and I also added the part numbers for the seat heating elements below just for added info.
68000519AA & 68000519AB (I assume one is for one side and the other for the other side.)
