Old Jun 10, 2010 | 09:43 PM
onehundred80
Default Re: Rotor and Hub Rust
Beautiful job Blast Chamber! BTW what are torque specs for the F&R caliper bolts? thanks
Slide Pins 85 ft/lbs, mounting bolts 40 ft/lbs. (from 2004 Manual)
Slide Pins 18 ft/lbs, mounting bolts 41 ft/lbs. (from 2005 Manual)
The 85 ft/lbs looks a bit too much to me.
In another Manual (05zh-service.pdf) it says the mounting bolts are 85 ft/lbs not 40 ft/lbs and slide pins are 18 ft/lbs.
These specs need correcting somewhere.
