Re: CP30 Pump = Leaking IC
Originally Posted by 32krazy!
i think in laymans terms woody is saying the cooling system he has has been pressurized to a max of the radiators cap ie: 15 psi. the pumps both stock and aftermarket are no more than 10 psi. so the pumps arent causing the ic to leak .
by using a lower temp thermostat he is also reducing the amount of pressure build up in the coolant system.
hope i understood you woody!
You also need to pump the tester up until the maximum pressure of the cooling system. If there is a fast leak the max psi may not need to be obtained before the leak is revealed.
