Old Jun 21, 2010 | 10:52 PM
02C32guy's Avatar
02C32guy
Default Re: Supercharger Oil
I have a spare can of Mobil Jet Oil II if anyone wants it. I bought two cans off a guy on ebay because it was cheaper than buying one can anywhere else. One can is more than enough for a lifetime. It's extremely simple to change. Here's a walk through I copied from MBWorld. Keep in mind these directions aren't mind, but rather ML500K's. Enjoy.'
Tools & Mats needed:
-E10 & E12
-largest syringe you can find , 100CC if possible
-12 inch r/c car fuel tubing or similar that can be attached to the tip of the syringe
- 1 bottle of A000 989 62 01 Supercharger Oil ( ONE bottle is all we need! ) Cost of oil is 60 dollars
- Some pipe thread white stuff, not sure what that is called ( see pics)
1) Use E10 to take off the secondary air pump plumbing brackets
2) Use E12 to take off the small pulley next to the SC ( if you still have one )
3) Use E10 to turn the belt tensioner to take off the belt
4) On the front of the SC and on the left side is a small hole with a screw,
you need to unscrew that , You should put some rags below it cause the oils might flow out and it really stinks.
5) Use a syringe to suck up the oil, this way you know how much was still in your SC to begin with. You will have to suck a few times to get all of it out.
6) Purge all oil from the syringe and tubing
7) Pour the new oil directly into the syringe ( as shown in the video ) and pump it in slowly. Repeat until the whole bottle is in. You might want an extra pair of hands to help you hold the syringe. YouTube - Replacing Supercharger Oil on C32
8) Thread the sc plug with white piping film
9) Screw the plug back into the SC until its tight. The plug should be a bit lower than flush to the sc
10) reinstall piping, brackets and make sure your belt is all lined up
11) start engine and check for to see if everything is in order.
