UPDATED 7/29/2011
Details:
Product: Wavetrac LSD for SLK32 & 320/SRT-6 & N/A (
Wavetrac® Differentials - Technical Information - © Autotech Corp. All rights reserved.)
Dealer: Unitrax - Anahiem, CA (POC: Devin King 1-800-622-4327)
* You will need to have it installed it in your current housing w/ stock ring/pinion. Unitrax can do installs also.
Cost: apx. $1100 + install
Shipping began around 15 Jun 2011 and will take apx 45 days to fill all orders.
*NOTE: If you have bolt-on axles (pre '03 SLKs and pre '05 Crossfires), you will be on-hold pending a solution. Autotech is testing a possible solution. It's looking like the stub axles will need to have the c-clip retaining grove machined to accept the snap-ring.
For those that don't know, this replaces the rear differential center carrier (spider gear assembly) that catastrophically fails. You will still use you stock housing, bearings and ring/pinion.
Feel free to contact Devin with other tech questions
I will keep this 1st post updated as new info arrives.
** If there are initials next to your screen name, then I have verified your real name with the deposits**
Buggin -- AB -- INSTALLED
daithi2 -- HD -- DELIVERED
MikeR -- MR -- DELIVERED
amx1397 -- JB -- INSTALLED
oledoc2u -- WH -- DELIVERED (x2)
velociabstract -- LH -- INSTALLED
32Krazy! -- SR -- INSTALLED
BigKid -- JR -- DELIVERED
Squirrel Crusher -- DB -- DELIVERED
Leptronjohn -- DELIVERED
Beaner -- BL -- INSTALLED
importlabsrt -- BT -- INSTALLED
Coyote -- WE -- DELIVERED
Dementors -- JB -- DELIVERED
Wedge -- SB -- DELIVERED
Waldig -- GW -- INSTALLED
Sik Srt-6 -- JL -- DELIVERED
rcompart -- RC -- DELIVERED
MrSix -- DELIVERED
scsponger31 -- DELIVERED
tri_zombie -- DELIVERED
brian_omeara07 -- BO -- DELIVERED
PA/XFIRE -- LS -- INSTALLED
KrzyFast -- PM -- DELIVERED
texas t -- DS -- DELIVERED
Tom2112 -- TD -- DELIVERED
ckovach -- CK -- DELIVERED
STANDBY LIST:
Kolevski -- JK
***The above list is of those that have made deposits (as far as I know) and may not be completely inclusive to all that have made deposits. This list was originally intended to gauge an interest to see if we could get enough orders to build a Wavetrac LSD. Unitrax has the official list of all deposits taken.***
NOTE: Credit Cards will be run for the the other half when your unit is shipped...
CONTACT INFO FOR DEPOSITS/ORDERING/QUESTIONS:
Devin B. King
UNITRAX Drivetrain, Inc.
1280 North Sunshine Way
Anaheim, CA 92806-1746
devin@gounitrax.com
714.630.4327
800.622.4327
Fax: 714.630.5851
