Re: Upper Radiator hose ALERT
The crimped type clamp is nothing new. Many cars use them now and entire assemblies must be purchased. Also if you come up with a leak around one of those clamps, you can cut them off very carefully with dremel, and then reuse a regular worm type clamp.
The clip (hanger) on the SRT is in a different place because the oil filter housing sets off more to the side of the engine to give room for the oil cooler attached. Compare the filter base location to the PS pump in your two pics, NA vs SRT. The clip is in the same location, just the base is moved out.
James
