Originally Posted by Stogey
I'm cornfused ! So if you can get the key to position one then you don't have to drill this pin out ???
Correct - if you can turn the key to position #1 then you don't have to drill out the pin shown in post #170 before you can remove the steering lock assy from the car. (there are 2 pins - post 175 shows the one you remove after you get the assy out)
