Originally Posted by HellFire
Hey, I have a quick question. If you have your car tuned, can't they fix the same issues a sprint booster fixes when they are tuning it? If so, how much is it to have a sprint booster installed vs a tune? If not, what is the gains to be had above flashing?
From what I undersatand, they are completely different. A tune can really wake up the motor by changing things such as timing, air/fuel mix ratios, RPM limiters, top speed limiters, etc. But to the best of my knowledge, it is completely independent of the throttle by wire system that the SB affects. It literally plugs in right behind the pedal in line with the throttle wiring....
