Old Jul 12, 2010 | 12:08 AM
pizzaguy
Default Re: Runs for 30 minutes dies won't restart
Originally Posted by 62Xfire
When I did push down on the plug that sits above the joints that are recommended for soldiering the relay would click laud and stall the car slightly
Well, there you go! Sounds like a broked/bad solder joint on the pins of the relay that controls the fuel pump.
Reflowing every joint on the board (and certainly any pin of any relays) should do the trick.
