Old Jul 16, 2010 | 01:34 PM
  #194 (permalink)
robwm's Avatar
robwm
Default Re: Sticky Ignition Key Fix!!: is just the pin the problem?
I have read the pdf file (great job; kudos to the author) and many of the related postings about the fix. Like others, I too have been quoted $1,000+ by the Chrysler dealer ...
From the comments it appears that the "locking pin" is the item at fault if the key will not turn.
I think that in my case this may be the problem because even when I can turn the key, my steering wheel does not really "lock" (when key is turned to the off position the wheel still rotates. which I interpret to mean that the pin is "jammed").
So it would seem that if someone can live without a "locking" steering wheel (I can, if it means saving some money) then removing/drilling-out the pin per the last page of the pdf instructions (:Re-Using Old Assembly") fixes the problem and will allow the key to rotate.
Am I interpreting this right? Is there another reason, that I've missed, for replacing the assembly with a new one? Has anyone had any problems after removing the pin permanently?
Last and most important, will just drilling the pin out (which can be done with a lot less fuss than taking the assembly out) work, or, does the spring also have to be removed?
I know this is a long running thread but I will appreciate your feedback ...
Thanks !!
