Originally Posted by Infinite
this is true. I can get a complete diff for 125, might just have to man up and get it so I can weld it.
Im just worried about the axles, and driveshaft. They are itty bitty compared to what I'm used to.
I'm trying to get in contact with the driveshaft shop about making a 1 piece aluminum driveshaft and aluminum insulators(to replace the weak rubber ones) for the 6-spd. Hopefully that pans out. I might send the axles as well so they can look them over.
a complete diff for 125$ im calling B.S.!! as for you knowing about the wavetrac before anybody on here may i remind you that the 32 guys were modding their cars a full 3 yrs before your car was even on a drawing board? the diff issue was a problem about the time you got your permit.
i realize thru your posts you are "the go to know all that there is" mojo modder but im here to tell you that lowering your car doesnt make you a modder. you speak before you think and show your ignorance on almost every post. if you can do all you say you can with your massive narcotic intake and physical limitations then surely you would have your own tv show by now.
if you dont have anything positive to say maybe you could take a break and build something for a change
and finally the one piece driveshaft was designed yrs ago for the slk32. made out of both carbon fiber and aluminium. not enough interest to produce the units due to the 1000$+ cost for each unit.
