Re: p0410 secondary air injection system malfunction solution?
Originally Posted by Black03AR
Thank tighed1,
Is it okay to clean the RCM with WD40? Or do you recommend using something else?
Oh hell no! LOL!
The area of concern is the contacts on the outside relay (thinking the left as you look at it) . Look to see if the contacts are black (BLACK is bad). I used a very small piece of folded fine sandpaper to get in between the contacts to clean mine. Perhaps a tinny tiny file, or if you can still find one, a contact burnisher might also work.
