Old Jul 29, 2010 | 09:57 PM
  #131 (permalink)
scsponger31's Avatar
scsponger31
Default re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Originally Posted by 32krazy!
brian the pumpkins are the same for both cars. autotech made the measurements off a xfire pumpkin. the difference is the way the axles mount to the diff, the srt-6 uses a snap ring and the slk32 uses a clip. both devin and autotech are aware of the minor difference and will address it.
i have a slk32 10 minutes away for the initial install and will be contacting a srt-6 owner tonight to see if he wants to test a unit also.
zorro i answered your question regarding the install of the diff. 225 $ bench install from unitrax , axles and reinstall into the car will depend on your mechanical ability or the amount of time the shop you choose will charge. if you dont have unitrax do the install of the diff into the carrier your shop should be familiar with lsd installs into a mercedes car
i personally want to thank everyone who is on board with this project. allen has worked a ton to get this going and its one of the few true custom items for our cars that is performance based. companys like needswings and autotech are our salvation when modding our cars and without the support of the members they wont build the parts we need. once again thanks to all of you!!!
I spoke with Devin today and everything looks good to use my car as the test car. He still expressed some concern, however, in regards the differences between the SLK and SRT. Hopefully we can get this figured out soon!
