Thread: I Got One!!!
Old Aug 1, 2010 | 12:20 AM
Franc Rauscher
Default Re: I Got One!!
Originally Posted by TomStratRT
I should also mention that the squeal or squeak is only heard during part of the wheel rotation, and not while the wheel is turning the whole time (uneven wear?). At high speeds on the highway, there is no noise at all. Only when driving in the city at low speeds and braking.
I'm under a 30 day full warranty and then I purchased a four year limited warranty as well, but the dealership is not exactly around the corner (like 45 minutes away with traffic).
Sounds more like warped rotors. Easy to do with aggresive driving.
Questin,
When you first start in the morning , no sounds until after you use the brakes and warm things up a bit?
If so, warped rotors is a likely possibility.
roadster with a stick
