Old Aug 2, 2010 | 01:30 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Water Pump Pulley Help
Originally Posted by scsponger31
This may be ignorance, but how do you get to the bearing on the water pump? The Pulley itself does not have a bearing, it is pretty much just a round plate.
I sent Eurocharged an email, so we will see what they say.
Does anyone know how difficult it is to replace the water pump?
Hope the PDF file helps.... Just remember - you have to remove the outer hub of the 185mm crank pulley to gain access all the water pump bolts - no need to remove the inner hub or crank bolt....
