Looks like you have the WP pulley that LET had to replace.
Contact EuroCharged and see if they can get you a replacement - if not then perhaps ASP will sell you one.
Does the WP itself look alright? Is the shaft loose or does it wobble? If not then your lucky.
Do you have the small idler pulley installed? How does it turn?
The shaft is not loose at all and does not appear to wobble but it is hard to tell. Also, it turns fine. How much play/wobble can I have without it causing a problem? If there is some it is not visible to the naked eye. I am hoping eurocharged will be able to send a new one.
