Originally Posted by Metin
my repair shop tells me he cant drill out the pin. he wants me to order new tumblers. what can i do?? any other way to get out the tumbler in a 0 key turn ?
I
think you could drill the tumbler like a locksmith would do, but then you would have to order new tumblers that match your key from the dealership and the dealership will probably charge you $1,000,000 for the tumbler itself. You have to drill out the pin to remove the ignition assembly. ordering new tumblers only is the most expensive way to go.
Just do it yourself; the fastest and cheapest way to get it done. If you can use a drill and screwdriver, then you can do it.
@typhoon55
ginkroW t'nerA slliP llihC
Link to post with picture tutorial of Sticky Ignition Fix
https://www.crossfireforum.org/forum...tml#post504963
