Re: What crank pulley did I buy?
Originally Posted by pelked1
Wow.
The reality of this is just now sinking in.
I spent around $700 for this?
1. Mystery crank pulley that clanks and measures only 171.5mm.
2. Used crankshaft bolt that may or may not be for an SRT6. Either way it's used.
3. Used water pump pulley that is prone to failing.
4. Idler pulley with a bearing that can't handle the peak RPMs and is likely to fail at some point.
I'm not even sure the pulley is for an SRT6 motor. Either way, I'm not using it.
I should have just taken seven $100 bills and flushed them down the toilet.
Damn.
Ask for you money back, this forum is a good place to request something like this in public.
Let everyone see the reply, let's face it is not good for business.
The parts are not used, and are dangerous to use.
If you don't ask you don't get.
