Originally Posted by hunt416
I was running recommended pressures 32/33 in my tires but kept getting the low pressure warning light. I took it to the dealer to have them check out the TPM system and they "fixed" it by putting 36 pounds in all the tires.
Now I get to go back to the dealer so they can fix my passenger side seat belt. I've been having nightmares about it.
Your dealer did you no favors by putting 36 psi in your tires. He cured the problem by adding more air than what the manual calls for. The real fix would be to have him calibrate the TPM system. If I remember correctly the owners manual makes mention of it. Good luck.
