Old Aug 12, 2010 | 07:43 PM
  #219 (permalink)
typhoon55's Avatar
typhoon55
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
[quote=rekcah]I think you could drill the tumbler like a locksmith would do, but then you would have to order new tumblers that match your key from the dealership and the dealership will probably charge you $1,000,000 for the tumbler itself. You have to drill out the pin to remove the ignition assembly. ordering new tumblers only is the most expensive way to go.
Just do it yourself; the fastest and cheapest way to get it done. If you can use a drill and screwdriver, then you can do it.
@typhoon55
ginkroW t'nerA slliP llihC
@rekcah
!!si romuh fo esnes ruoy tsael ta
niap ruoy leef od I
