Old Aug 15, 2010 | 01:20 PM
onehundred80
Default Re: Turn signals suddenly stop working...
Originally Posted by tonygg
Thanks! Is the fuse found on the headlight switch module or in the fuse box? I find it curious that I swapped out the headlight switch module last year for an American type (no DRL's). Maybe I should re-seat the switch module?
I may be wrong, and I often am, but the flasher is a part of the multi-function switch and is not replaceable on its own. OUCH!
I hope it's something simple and cheap to fix.
The multi-function switch is attached to the turn signal lever. You probably get a new lever as well.
