re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
Rudy sent me the stub a week ago,,My son came over to help because i had eye surgery on monday and was told don't bend over don't lift ,,,just rest. anyway weI tried a stock spring clip (.076) it would not work, the axle would not go into the gear th spring clip was too big, then i tried a smaller one that i had, (.060) the axle went in but had so much play it would have leaked oil at the seal. then i tried two of the .060 they fit perfect into the axle and went into the rear like it was soppose too ,,very little play, movement,,about the same as a stock axle,,, then i tried to remove the stub axle , i pried from the inside i pulled from the outside, I had to again remove the spring clips with two LITTLE screwdrivers working inside the rear, now 8 days later my son is comming over tomorrow to re try with a new spring clip. so i will have a answer tomorrow. i hope. jim
