re: *Needed* 20 to Pre-order Wavetrac LSD for SLK32/SRT-6
jim when i talked to rudy he said he sent you a slk32 axle. can you confirm which axle you were using? c32 or slk32?
my idea is by being able to use the slk32 stub axles when the gear ratio change is figured out i can drop my diff and leave the axles in place. change gears for the racetrac or mile then reinstall my 3.07 for the street
