Re: SRT engine into N/A
it"s wayyyy cheaper to just buy the SRT and repaint it after removing the wing and changing the front bumper cover.
Unless you think it"s easy to reprogram a Mercedes ECU to work with the security system in your car, switch over the brakes, suspension, etc.
It's not just as easy as swapping in a engine and calling it all good.
Why am I even answering this....... use the search feature of the forum.... if you don't have patience enough to research this with a simple search then you DEFINITELY don't have patience enough to start switching engines and ECU's on a Mercedes vehicle.
