SRT engine into N/A
Old Aug 23, 2010 | 01:07 PM
FUBU's Avatar
Default Re: SRT engine into N/A
Originally Posted by apkano
it"s wayyyy cheaper to just buy the SRT and repaint it after removing the wing and changing the front bumper cover.
Unless you think it"s easy to reprogram a Mercedes ECU to work with the security system in your car, switch over the brakes, suspension, etc.
It's not just as easy as swapping in a engine and calling it all good.
Why am I even answering this....... use the search feature of the forum.... if you don't have patience enough to research this with a simple search then you DEFINITELY don't have patience enough to start switching engines and ECU's on a Mercedes vehicle.
Okay thanks for the heads up. Btw I have searched for it and read all from hdhhd user, v8conversion. But always good to ask to see whether new users know anything. But hey, I will try not to **** anyone off by asking or just stating my opinion. Many thanks yet again to everyone giving me answers.
Cheers
Old Aug 26, 2010 | 10:42 AM
Walters5507's Avatar
Cool Re: SRT engine into N/A
Cheers
Don't get discouraged by some of the comments made on here. I've noticed in almost every thread that somewhere along the line, someone get's defensive and types something they shouldn't. Everytually, you learn to disregard derogitory comments made by people that aren't completing their thought process in the comment they read. Brush it off, Love your Crossfire, and do what will ultimately make you happiest. It's all good man.
Old Aug 26, 2010 | 04:44 PM
FUBU's Avatar
Thanks m8
Old Aug 26, 2010 | 06:03 PM
downwardspiral's Avatar
realistically, plan on spending that plus a couple thousand dollars for tools and unforseen expenses to do it yourself. You can probably pull it off if you are really into it, you will just need to do a decent amount of research and work. You should study the SRT and limited shop manuals and figure out what would be the same beforehand.
Old Sep 28, 2010 | 05:46 AM
FUBU's Avatar
Default SRT engine
Sry for asking this again but I have found a SRT6 engine with the ignition, keys and so forth. gone 600 miles. Can it be put into my N/A? if not, can I take of all the tuning parts S/C from the engine and bolt it on to mine? please help.
Kind regards,
Phil
Old Sep 28, 2010 | 12:23 PM
MikeR's Avatar
Phil, I believe that you are best to do the complete swap of the SRT6 drive train into your car.... you can not swap parts from the SRT onto the NA without major headaches from what I have read....
The SRT6 swap may require some reprogramming...Rudy could handle that I think..
Old Sep 28, 2010 | 12:35 PM
Kind regards,
Phil
Get as much electronics as yopu can from the donor car. You will have to convince the new motor that it is safely in a chassis it recognizes as "home."
Or it simply won't start.
As MikeR suggested, lean on RCompart. If he doesn't have the answer, he likely knows somebody who does. Absolutely the best friend you could have on a project like this.
I still say you wallet will smart a bit. But hell man, seems you mind is made up. So, go for it.
Old Sep 28, 2010 | 12:53 PM
bmorgan's Avatar
Just my 2 cents, but if you do not have the technical ability to do it, and you have to rely on a mechanic to do it.......... You will spend way more on the conversion that what it would be worth. And, you had better find a great mechanic that not only understands the electronics on these babies, but also has the proper equipment to do the reprogramming. Just try to understand all the costs up front before you jump in, and expect your mechanic to come back to you with obstacles that they will have to overcome which will increase costs that you were not expecting. Good luck with it. Personally, I would sell the NA, and purchase an SRT as there is much more than just the engine difference between the NA and SRT to include brakes, suspension, rear differential, etc.
Or, plan "B"...........
Fly Rudy over to Sweden for a couple of weeks, and have him install a 5.5 SC engine in it. Now that would be worth the upgrade.
Old Sep 28, 2010 | 01:06 PM
FUBU's Avatar
The rudy part I have actually thought about and discussed with him. But seem to be easier for all of us for me just to buy an SRT. :'D
Old Sep 28, 2010 | 01:14 PM
bmorgan's Avatar
Hell, for what they sell for in Sweden, buy 2 SRT's here...... send them back........ sell 1 and drive the other for free. LOL
Old Sep 28, 2010 | 03:05 PM
FUBU's Avatar
That is actually quite a good idea. What I will do is to find a nice SRT6 and then sell my N/A here in Sweden.
Old Sep 28, 2010 | 03:33 PM
bigblock427's Avatar
O.k. - what's different - afaik:
Engine
Engine harness
Engine cooling system
Manifold
Complete exhaust system incl. catalysator (other diameter) and other mufflers
Engine ECU
Instruments can be switched with MB Star DAS, but gauge will then be wrong
Suspension - 10 mm lower
Brake system - bigger radiators and other calipers
Tranny is different - also ECU for tranny
Differential is different - other ratio
Rear axles are different
Stabilizers are different
Complete electrics have to be resetted and learned on new - needs Star DAS
Seats
Front fender
Rear wing
Rims
Old Sep 28, 2010 | 03:51 PM
FUBU's Avatar
Engine
Engine harness
Manifold
Engine ECU
Seats
Front fender
Rear wing
Rims
Okay, It will be much easier to buy a whole car.
Best place to find one in FL area?What are the prices for repainting a whole car in the US?
Old Sep 28, 2010 | 05:36 PM
BrianBrave's Avatar
<--- Huge Horsepower
Perhaps you could buy a salvage SRT6 that runs great. You would then have everything you need from the donor car for the swap; plus the donor car to see how it all fits/works/hooks up.
After your up and running, you can sell the leftovers to recoupe your expenses..
Old Sep 28, 2010 | 05:56 PM
FUBU's Avatar
unfortuately no market for parts here in Sweden. A very unusual car here,..
now its time for bed.
thanks for all the ideas.
Bye
Old Sep 28, 2010 | 06:26 PM
Bye
You have more ideas than anyone here, so don't blame us.
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
RED DOG
Jul 22, 2015 08:55 AM
RED DOG
Jul 21, 2015 07:58 AM
bradleykologek
Jul 6, 2015 02:49 PM
