Originally Posted by MAGNATUDE
Ok, so I'm getting a LITTLE frustrated here. I ordered a replacement fan assembly on Tuesday (Dorman 620-040 from Rock Auto) got it today, put it in, FAN WILL NOT TURN ON, even with a/c running! Modulator anyone??
Kara
Relax Kara, It has to be the fuse then. Simply replace the fan fuse (check first) and most likely it will fix your problem.
If not, it is probably the control module but then your old fan should have been fine. I never heard or read both parts going bad at the same time. It is generally either or.
