Thread: Radiator Fan
Old Aug 26, 2010 | 09:49 PM
Musclefan21's Avatar
Musclefan21
Default Re: Radiator Fan
Originally Posted by MAGNATUDE
Thanks so much for all of your help, guys! I am still going to try and order a 50 amp fuse even though it is still good, I will likely have to order it though as Musclefan suggested. Woody, thanks so much for offering to walk me through testing the new fan! I just tested it with my clip lead and it ran just as it should. (12v through the battery) I also went ahead and tested the old fan again and sparks flew, but the fan did not turn. That leads me to believe that the fan motor may have seized and then "allegedly" fried the module?? Looks like that is the only other "suspect"....I'll keep you guys posted!
The part # listed on the module is A 025 545 59 32...only found one online source for the part @ around $230 and it is listed as a "Mercedes MSA Control", anyone know of any other sources for this part?
Kara
I doubt that is the case. My fan motor's bearings were all messed up. it was stuck like yours, wobbling and sparkling, etc. Mine would have fried the module as well but it didnt. Heck it didnt even do anything to the fuse nor the module. I put the new fan and it ran.
I hope your module is fine. Let start with fuse. if the new fuse doesnt fix it, I am afraid only one more thing left to try and thAt is the module.
